anleitung docx converter word 2007 für dummies
Dieses Thema im Forum "Software" wurde erstellt von fiorentino, 16. April 2007.
  1. fiorentino
    fiorentino New Member
    Ich habe ein mail mit dem neuen word 2007 format .docx bekommen.
    Daraufhin habe ich mir das widget docx.converter von runtergeladen - und nun - wie konvertiere ich? Drag und drop geht nicht...
    Weiss einer von Euch weiter??
  2. TomPo
    TomPo Active Member
    How to use it?
    In Office 2007 Microsoft introduced a new file format called the Microsoft Open Office XML Format (.docx). This format is not compatible with older versions of Microsoft Word or with alternative operating systems like Linux or Mac OS X. Nor is it compatible with other word processing applications like OpenOffice, Lotus 123, or NeoOffice.
    The Docx-converter Dashboard Widget allows you to convert files right from your Desktop. Simply drag the .docx file you want to convert into the drop area of the widget (click to drag, push F12, drop) and the widget will automatically convert the file and save it to the location of the original file (with a .htm extension) and (optionally) open it in your web browser. Best of all, any updates or feature additions to the website will automatically be reflected in the widget!
