Avi ohne Ton
Dieses Thema im Forum "Software" wurde erstellt von arnbas, 30. November 2005.
  1. arnbas
    arnbas New Member
    Folgender Player:
    QuickTime™ Version 7.0.3, Player Version 7.0.3 (7.0.3)
    mit diesen installierten Komponenten:
    /Library/QuickTime/3ivx D4 PR1 Decoder OSX
    /Library/QuickTime/AC3 Codec.component
    /Library/QuickTime/ACTLComponent.qtx
    /Library/QuickTime/AppleIntermediateCodec.component
    /Library/QuickTime/AvidAVDJCodec.component
    /Library/QuickTime/AvidAVdvCodec.component
    /Library/QuickTime/AvidAVUICodec.component
    /Library/QuickTime/AXELplayer.qtx
    /Library/QuickTime/BUILDING.txt
    /Library/QuickTime/CompOptions.r
    /Library/QuickTime/COPYING
    /Library/QuickTime/DivX 5.component
    /Library/QuickTime/DivX 6 Decoder.component
    /Library/QuickTime/DivX Pro 5 - 2nd.component
    /Library/QuickTime/EX_M4S2.component
    /Library/QuickTime/IconsAndVersion.r
    /Library/QuickTime/KinomaExporter.component
    /Library/QuickTime/lame 3.92.shlb
    /Library/QuickTime/LAMECodec.h
    /Library/QuickTime/LAMEComponent.nib
    /Library/QuickTime/LAMEComponent.xcode
    /Library/QuickTime/LAMEEncoder-Info.plist
    /Library/QuickTime/LAMEEncoder.component
    /Library/QuickTime/LAMEExport.r
    /Library/QuickTime/LAMEExportDispatch.h
    /Library/QuickTime/LAMEExportMovie.c
    /Library/QuickTime/LameLib
    /Library/QuickTime/MegaPEG.QT.component
    /Library/QuickTime/Microcosm Decode.component
    /Library/QuickTime/MP3.component
    /Library/QuickTime/OggVorbis.component
    /Library/QuickTime/on2vp3.component
    /Library/QuickTime/PBExports.exp
    /Library/QuickTime/PPCMachO.r
    /Library/QuickTime/PSIKeyMac.shlb
    /Library/QuickTime/QTFbx.component
    /Library/QuickTime/RealMediaExporter.component
    /Library/QuickTime/Save as AVI.component
    /Library/QuickTime/Toast Video CD Support.qtx
    /Library/QuickTime/Zoomify.component
    /Library/QuickTime/ZyGoVideo.component
    spielt avi-Filme mit diesem Codec ohne Ton:
    (Infofenster von VLC)
    Stream 0
    Codec DX50
    Typ Video
    Stream 1
    Codec a52
    Typ Audio
    Abtastrate 48000Hz
    Bitrate 448 KB/s
    Ich kann mir die Filme zwar mit VLC am Mac ansehen, möchte sie aber als
    DVD am Fernseher gucken. Toast 7 Titanium hat wunderschöne DVDs erstellt, leider aber auch ohne Ton.
    Wer weiß Rat?
  2. 55DSL
    55DSL New Member
    Hallo
    Das Problem ist die Tonspur nach deinen Angaben handelt es sich höchstwarscheinlich um einen AC 3 5.1 Ton. Toast 7 verarbeitet aber nur AC 3 2.0 (Stereo). Eine Umwandlung von AC 3 5.1 in AC 3 2.0 ist nicht so einfach möglich . Benutze Streamclip, öffne die Datei exportiere den Ton in Aiff , wird zwar ziehmlich groß und sichere diesen. Wenn du den Ganzen Film wieder an Toast gibst fragt dich Toast ob eine gesonderte Tonspur vorhanden ist. Wähle den Aiff Ton aus und markiere die Option das der Ton in AC3 2.0 umgewandelt werden soll. So sollte es gehen. Kann es mangels Zeitdruck nicht testen. Die Richtung stimmt aber.
    Viel Glück
  3. arnbas
    arnbas New Member
    Erst mal danke, wo finde ich Streamclip?
  4. arnbas
    arnbas New Member
    Streamclip habe ich gefunden, allerdings sagt das Programm bei den entsprechenden Auswahlen kein Audio zum export vorhanden bzw. ungültige Aufgabe.
  5. apoc7
    apoc7 New Member
    Installier doch mal den AC3-Codec für Quicktime. Gibt es bei Versiontracker.
  6. arnbas
    arnbas New Member
    So weit ich meine installierten Komponenten richtig lese habe ich den schon installiert, oder gibt es noch einen anderen?
  7. Mathias
    Mathias New Member
    Vielleicht kannst Du den Ton mit ffmpegx exportieren bzw. das ganze Video in ein anderes Format umwandeln.
  8. Mathias
    Mathias New Member
    Vielleicht kannst Du den Ton mit ffmpegx exportieren.
  9. arnbas
    arnbas New Member
    Ich habe gerade auch den Tip bekommen, es mit DivXRay mal zu probieren,
    das werde ich jetzt tun und dann berichten.
  10. arnbas
    arnbas New Member
  11. Mano
    Mano New Member
    Schade!
    Der Dowload-Link funktioniert nicht. Und bei MacUpdate gibt es das Teil erst gar nicht.
    Mano
