Fast Ethernet für 9650/350
Dieses Thema im Forum "Software" wurde erstellt von WalterRipley, 25. März 2001.
  1. WalterRipley
    WalterRipley New Member
    Hi guys,
    i`m searching a small Extension called:
    10/100 Fast Ethernet
    It is located on the Cd of the Workgroupserver
    PowerMac 9650/350
    Please if you now someone or you have a 9650 or 7350
    please email me this small extension.
    Thanks and greetings from
    Cologne/Germany
    Walter
    This is a question from the Apple Tech Info Archive :
    TITLE
    Workgroup Server 9650/350 and Fast Ethernet
    Article ID:
    Created:
    Modified: 22151
    2/18/98
    2/18/98
    TOPIC
    I have a Workgroup Server 9650/350 which came with an 10/100 Ethernet card. What do I need to do to get the card working on my 100Base-T network.
    DISCUSSION
    The Fast Ethernet card you describe is included with all Workgroup Server 9650/350 configurations. This Fast Ethernet card is not available on the Workgroup Server 9650/233. The software you need is the Apple 10/100 Fast Ethernet extension which you'll find it on the WGS CD in the Server Additions folder. When the Apple 10/100 Fast Ethernet extension is installed, you will see an additional choice in the AppleTalk and TCP/IP control panels, Ethernet Slot D2.
    NOTE: The driver does not support raw mode. If you need raw mode, you have to use built-in Ethernet.
  2. WalterRipley
    Hi guys,
    PowerMac 9650/350
    Cologne/Germany
    Walter
    TITLE
    Article ID:
    Created:
    Modified: 22151
    2/18/98
    2/18/98
    TOPIC
    DISCUSSION
