Ich sag nur...
Dieses Thema im Forum "Small Talk" wurde erstellt von Go610, 30. Juni 2004.
  1. Go610
    Go610 New Member
    ...folgendes:
    Zugriffsrechte für „Macintosh HD“ überprüfen
    Determining correct file permissions.
    Permissions differ on ./Applications/iPhoto.app/Contents/Resources/BurnFailed.aiff, should be -rw-rw-r-- , they are -rwxrwxr-x
    Permissions differ on ./Applications/iPhoto.app/Contents/Resources/BurnSuccess.aiff, should be -rw-rw-r-- , they are -rwxrwxr-x
    Permissions differ on ./Applications/iPhoto.app/Contents/Resources/Scripts/America Online.scpt, should be -rw-rw-r-- , they are -rwxrwxr-x
    Permissions differ on ./Applications/iPhoto.app/Contents/Resources/Scripts/Eudora.scpt, should be -rw-rw-r-- , they are -rwxrwxr-x
    Permissions differ on ./Applications/iPhoto.app/Contents/Resources/Scripts/Microsoft Entourage.scpt, should be -rw-rw-r-- , they are -rwxrwxr-x
    Permissions differ on ./Applications/iPhoto.app/Contents/Resources/SendToiDVD.scpt, should be -rw-rw-r-- , they are -rwxrwxr-x
    User differs on ./Library/Image Capture/TWAIN Data Sources, should be 0, owner is 501
    Group differs on ./Library/Image Capture/TWAIN Data Sources, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Frameworks/hpImaging.framework/Versions/B/hpImaging, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/IO/HPDJIP_IOM.plugin/Contents/MacOS/HPDJIP_IOM, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/IO/HPDJIP_PBM.plugin/Contents/MacOS/HPDJIP_PBM, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/IO/HPDJIP_PBM.plugin/Contents/Resources/gaboonvers, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/PDEs/hpColorOptions.plugin/Contents/MacOS/hpColorOptions, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/PDEs/hpEdgeToEdge.plugin/Contents/MacOS/hpEdgeToEdge, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/PDEs/hpFinishing.plugin/Contents/MacOS/hpFinishing, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/PDEs/hpImageQuality.plugin/Contents/MacOS/hpImageQuality, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/PDEs/hpProofAndPrint.plugin/Contents/MacOS/hpProofAndPrint, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/business inkjet 1100.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/deskjet 5100.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/deskjet 5600.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/deskjet 5800.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp color inkjet cp1160.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp color inkjet cp1700.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp designjet 100.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp designjet 10ps.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp designjet 110.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp designjet 120.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp designjet 120nr.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp designjet 20ps.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp designjet 50ps.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 1125c.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 1180C.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 1220C.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 3320.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 3420.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 350.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 3500 series.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 3600 series.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 3810.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 3816.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 3820.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 450.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 5550.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 5551.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 6122.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 6127.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 810-812.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 815.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 816.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 825c.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 830-832.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 840-842-843.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 845c.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 880-882.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 895.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 920C.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 9300.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 930C.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 935C.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 940C.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 948C.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 950C.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 955C.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 957.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 9600.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 960C.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 970C.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 980C.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 990C.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp deskjet 995C.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/hp photosmart 7150.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/officejet 4100 series.plst, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/officejet 4100 series.plst, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/officejet 4100 series.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/officejet 4105.plst, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/officejet 4105.plst, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/officejet 4105.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/officejet 5500 series.plst, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/officejet 5500 series.plst, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/officejet 5500 series.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/officejet 6100 series.plst, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/officejet 6100 series.plst, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/officejet 6100 series.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 1000 series.plst, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 1000 series.plst, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 1000 series.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 1100 series.plst, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 1100 series.plst, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 1100 series.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 1200 series.plst, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 1200 series.plst, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 1200 series.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 1300 series.plst, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 1300 series.plst, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 1300 series.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 2100 series.plst, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 2100 series.plst, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 2100 series.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 2150 series.plst, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 2150 series.plst, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 2150 series.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 2170 series.plst, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 2170 series.plst, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 2170 series.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 2200 series.plst, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 2200 series.plst, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 2200 series.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 2300 series.plst, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 2300 series.plst, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 2300 series.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 2400 series.plst, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 2400 series.plst, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 2400 series.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 2500 series.plst, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 2500 series.plst, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/Printer Model Data Files/psc 2500 series.plst, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Frameworks/NetSupportX.bundle/Contents/Info.plist, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Frameworks/NetSupportX.bundle/Contents/Info.plist, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Frameworks/NetSupportX.bundle/Contents/MacOS/NetSupportX, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Frameworks/NetSupportX.bundle/Contents/MacOS/NetSupportX, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Frameworks/NetSupportX.bundle/Contents/MacOS/NetSupportX, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Frameworks/NetSupportX.bundle/Contents/MacOS, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Frameworks/NetSupportX.bundle/Contents/MacOS, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Frameworks/NetSupportX.bundle/Contents/Resources/English.lproj/InfoPlist.strings, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Frameworks/NetSupportX.bundle/Contents/Resources/English.lproj/InfoPlist.strings, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Frameworks/NetSupportX.bundle/Contents/Resources/English.lproj, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Frameworks/NetSupportX.bundle/Contents/Resources/English.lproj, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Frameworks/NetSupportX.bundle/Contents/Resources, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Frameworks/NetSupportX.bundle/Contents/Resources, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Frameworks/NetSupportX.bundle/Contents, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Frameworks/NetSupportX.bundle/Contents, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Frameworks/NetSupportX.bundle, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Frameworks/NetSupportX.bundle, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Frameworks, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Frameworks, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Info.plist, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Info.plist, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/ScanDevices.bundle/Contents/Info.plist, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/ScanDevices.bundle/Contents/Info.plist, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/ScanDevices.bundle/Contents/MacOS/ScanDevices, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/ScanDevices.bundle/Contents/MacOS/ScanDevices, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/ScanDevices.bundle/Contents/MacOS/ScanDevices, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/ScanDevices.bundle/Contents/MacOS, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/ScanDevices.bundle/Contents/MacOS, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/ScanDevices.bundle/Contents/PkgInfo, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/ScanDevices.bundle/Contents/PkgInfo, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/ScanDevices.bundle/Contents/Resources/English.lproj/InfoPlist.strings, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/ScanDevices.bundle/Contents/Resources/English.lproj/InfoPlist.strings, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/ScanDevices.bundle/Contents/Resources/English.lproj, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/ScanDevices.bundle/Contents/Resources/English.lproj, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/ScanDevices.bundle/Contents/Resources, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/ScanDevices.bundle/Contents/Resources, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/ScanDevices.bundle/Contents, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/ScanDevices.bundle/Contents, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/ScanDevices.bundle, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/ScanDevices.bundle, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBIOBundle.bundle/Contents/Info.plist, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBIOBundle.bundle/Contents/Info.plist, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBIOBundle.bundle/Contents/MacOS/USBIOBundle, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBIOBundle.bundle/Contents/MacOS/USBIOBundle, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBIOBundle.bundle/Contents/MacOS/USBIOBundle, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBIOBundle.bundle/Contents/MacOS, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBIOBundle.bundle/Contents/MacOS, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBIOBundle.bundle/Contents/PkgInfo, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBIOBundle.bundle/Contents/PkgInfo, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBIOBundle.bundle/Contents/Resources/English.lproj/InfoPlist.strings, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBIOBundle.bundle/Contents/Resources/English.lproj/InfoPlist.strings, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBIOBundle.bundle/Contents/Resources/English.lproj, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBIOBundle.bundle/Contents/Resources/English.lproj, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBIOBundle.bundle/Contents/Resources, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBIOBundle.bundle/Contents/Resources, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBIOBundle.bundle/Contents, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBIOBundle.bundle/Contents, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBIOBundle.bundle, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBIOBundle.bundle, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBLIDIL.bundle/Contents/Info.plist, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBLIDIL.bundle/Contents/Info.plist, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBLIDIL.bundle/Contents/MacOS/USBLIDIL, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBLIDIL.bundle/Contents/MacOS/USBLIDIL, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBLIDIL.bundle/Contents/MacOS/USBLIDIL, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBLIDIL.bundle/Contents/MacOS, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBLIDIL.bundle/Contents/MacOS, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBLIDIL.bundle/Contents/PkgInfo, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBLIDIL.bundle/Contents/PkgInfo, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBLIDIL.bundle/Contents/Resources/English.lproj/InfoPlist.strings, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBLIDIL.bundle/Contents/Resources/English.lproj/InfoPlist.strings, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBLIDIL.bundle/Contents/Resources/English.lproj, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBLIDIL.bundle/Contents/Resources/English.lproj, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBLIDIL.bundle/Contents/Resources, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBLIDIL.bundle/Contents/Resources, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBLIDIL.bundle/Contents, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBLIDIL.bundle/Contents, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBLIDIL.bundle, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/USBLIDIL.bundle, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/hp inkjet toolbox, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/hp inkjet toolbox, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic/hp inkjet toolbox, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/MacOSClassic, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/PkgInfo, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/PkgInfo, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1000-No Brand Test Page.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1000-No Brand Test Page.pcl, should be 80, group is 501
  2. Go610
    Go610 New Member
    app/Contents/Resources/1008-PathFndrVeniceCalStart.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1008-PathFndrVeniceCalStart.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1009-PathFinderVeniceVerify.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1009-PathFinderVeniceVerify.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1009-PathFinderVeniceVerify.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1011-EmeraldTestPage.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1011-EmeraldTestPage.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1011-EmeraldTestPage.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1018-EmeraldClean.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1018-EmeraldClean.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1018-EmeraldClean.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1019-EinsteinplusClean.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1019-EinsteinplusClean.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1019-EinsteinplusClean.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1020-EinsteinplusReClean.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1020-EinsteinplusReClean.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1020-EinsteinplusReClean.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1021-EinsteinplusPrime.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1021-EinsteinplusPrime.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1021-EinsteinplusPrime.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1022-EinsteinplusTestPage.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1022-EinsteinplusTestPage.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1022-EinsteinplusTestPage.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1023-EinsteinplusCalStart.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1023-EinsteinplusCalStart.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1023-EinsteinplusCalStart.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1024-EinsteinplusVerify.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1024-EinsteinplusVerify.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1024-EinsteinplusVerify.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1026-PhobosCalBlackOnly.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1026-PhobosCalBlackOnly.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1026-PhobosCalBlackOnly.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1027-PhobosCalCMYOnly.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1027-PhobosCalCMYOnly.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1027-PhobosCalCMYOnly.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1028-PhobosVerifyKorCMY.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1028-PhobosVerifyKorCMY.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1028-PhobosVerifyKorCMY.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1029-ThriftwayCal.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1029-ThriftwayCal.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1029-ThriftwayCal.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1030-ThriftwayVerify.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1030-ThriftwayVerify.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1030-ThriftwayVerify.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1031-ZCA Page.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1031-ZCA Page.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1031-ZCA Page.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1033-JupiterEulerClean.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1033-JupiterEulerClean.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1033-JupiterEulerClean.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1034-JupiterEulerReClean.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1034-JupiterEulerReClean.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1034-JupiterEulerReClean.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1035-JupiterEulerPrime.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1035-JupiterEulerPrime.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1035-JupiterEulerPrime.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1036-JupiterEulerCalibrate.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1036-JupiterEulerCalibrate.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1036-JupiterEulerCalibrate.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1037-JupiterEulerColorCal.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1037-JupiterEulerColorCal.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1037-JupiterEulerColorCal.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1038-JupiterEuler Diag.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1038-JupiterEuler Diag.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1038-JupiterEuler Diag.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1039-Diagnostic (Bdwy,Aldn).pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1039-Diagnostic (Bdwy,Aldn).pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1039-Diagnostic (Bdwy,Aldn).pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1055-VIP Test Page.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1055-VIP Test Page.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1055-VIP Test Page.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1064-SubwayCal.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1064-SubwayCal.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1064-SubwayCal.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1065-SubwayVerify.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1065-SubwayVerify.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1065-SubwayVerify.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1066-Diagnostic Page(PML).pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1066-Diagnostic Page(PML).pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1066-Diagnostic Page(PML).pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1067-Ernst Man Cal Start.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1067-Ernst Man Cal Start.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1067-Ernst Man Cal Start.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1068-Diagnostic 4-Btn Press.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1068-Diagnostic 4-Btn Press.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1068-Diagnostic 4-Btn Press.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1069-Ernst Man Cal Verify.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1069-Ernst Man Cal Verify.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1069-Ernst Man Cal Verify.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1071-Crick Test Page.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1071-Crick Test Page.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1071-Crick Test Page.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1100-Cancel.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1100-Cancel.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1100-Cancel.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1200-HP Deskjet Test Page.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1200-HP Deskjet Test Page.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1200-HP Deskjet Test Page.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1302-Crystal Color Cal.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1302-Crystal Color Cal.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1302-Crystal Color Cal.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1303-4Ink Plot.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1303-4Ink Plot.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1303-4Ink Plot.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1304-6Ink Plot.pcl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1304-6Ink Plot.pcl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/1304-6Ink Plot.pcl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/CMY_bidi.ldl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/CMY_bidi.ldl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/CMY_bidi.ldl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Crossbow_VerifyPage, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Crossbow_VerifyPage, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Crossbow_VerifyPage, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Dutch.lproj/Localized.rsrc, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Dutch.lproj/Localized.rsrc, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Dutch.lproj, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Dutch.lproj, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/English.lproj/Localized.rsrc, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/English.lproj/Localized.rsrc, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/English.lproj, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/English.lproj, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/French.lproj/Localized.rsrc, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/French.lproj/Localized.rsrc, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/French.lproj, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/French.lproj, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/German.lproj/Localized.rsrc, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/German.lproj/Localized.rsrc, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/German.lproj, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/German.lproj, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Italian.lproj/Localized.rsrc, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Italian.lproj/Localized.rsrc, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Italian.lproj, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Italian.lproj, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Japanese.lproj/Localized.rsrc, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Japanese.lproj/Localized.rsrc, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Japanese.lproj, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Japanese.lproj, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/K_bidi.ldl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/K_bidi.ldl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/K_bidi.ldl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/KtoCMY.ldl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/KtoCMY.ldl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/KtoCMY.ldl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Portuguese.lproj/Localized.rsrc, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Portuguese.lproj/Localized.rsrc, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Portuguese.lproj, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Portuguese.lproj, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Spanish.lproj/Localized.rsrc, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Spanish.lproj/Localized.rsrc, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Spanish.lproj, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Spanish.lproj, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Swedish.lproj/Localized.rsrc, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Swedish.lproj/Localized.rsrc, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Swedish.lproj, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/Swedish.lproj, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cb2pcal.ldl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cb2pcal.ldl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cb2pcal.ldl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cbbcal.ldl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cbbcal.ldl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cbbcal.ldl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cbccal.ldl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cbccal.ldl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cbccal.ldl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cbcp2pen.ldl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cbcp2pen.ldl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cbcp2pen.ldl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cbcpcmy.ldl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cbcpcmy.ldl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cbcpcmy.ldl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cbcpk.ldl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cbcpk.ldl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cbcpk.ldl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cmk_bidi.ldl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cmk_bidi.ldl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cmk_bidi.ldl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cmktoCMY.ldl, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cmktoCMY.ldl, should be 80, group is 501
    Permissions differ on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/cmktoCMY.ldl, should be -rwxrwxr-x , they are -rw-rw-r--
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/deskjet.icns, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/deskjet.icns, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/hp inkjet toolbox.rsrc, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources/hp inkjet toolbox.rsrc, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents/Resources, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app/Contents, should be 80, group is 501
    User differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app, should be 0, owner is 501
    Group differs on ./Library/Printers/hp/Utilities/hp inkjet toolbox.app, should be 80, group is 501
  3. Go610
    Go610 New Member
    könnte noch 4 Beiträge lang so weitergehen...
    Da frag ich mich echt, was für schlampige Programmierer HP anheuert.
    vielleicht sollte ich mal das dem HP-Support schicken :D
  4. constanze
    constanze New Member
    hallo,
    ich hoffe, dass mir hier vielleicht jemand weiterhelfen kann!?
    mein buero hat einen neuen plotter gekauft, einen hp designjet 5500ps uv, den ich seit tagen verzweifelt an mein powerbook und somit an OS 10.4.7. anzuschliessen versuche.
    was ich auch mache, mein testbild kommt immer mit falschen farben heraus. alles, was grau oder weiss ist, wird blau-gruen und ich bin mir sicher, dass es nicht am plotter liegt, der naemlich das in seinem eigenen menue vorhandene demo-bild super ausdruckt.
    hp's telefon-support schiebt das problem zu apple, die zu schnell aktualisieren wuerde und da wuerden sie nicht hinterher kommen.
    es liegt wohl an der farbkalibrierung des treibers und genau die kann ich irgendwie bei meinem apple-driver (driver version 3.0.2) nicht finden.
    ich drucke uebrigens aus indesign oder illustrator (falls das als info hilft).
    ich wuerde mich sehr ueber tips freuen!
    ich kann doch nicht die einzige sein, die einen neuen mac hat und diesen plotter!?
    vielen dank! gruss, constanze.
  5. Singer
    Hallo, constanze,
    mach mit Deinem Problem lieber mal einen eigenen thread auf, vielleicht im software-Brett. Wenn man diesen hier anschaut und die Liste mit Fehlermeldungen sieht, klickt man nämlich nur entnervt wieder weg, ohne bis zu Deiner Frage 'runterzuscrollen.
    Gruß nach Kopenhagen…
