O lala - iTunes, trekkies und anderes...
Dieses Thema im Forum "Software" wurde erstellt von starwatcher, 10. April 2001.
  1. starwatcher
    starwatcher New Member
    hot off the press (www.macfixit.com)
    Odds & Ends: Kerbango to go silent;
    Vectorworks and Driver Update extension conflict?
    Kerbango to shut down Kerbango will be shutting down soon. A note on their Web site states: "3Com is closing down its Internet Appliance Division. Since August of last year Kerbango has been part of that division, so we too will be going away. To those who actually got to see and use the Kerbango radio, we would like to thank you for your kind words and reviews. We showed the world the stand-alone Internet radio. May our path lead the way for those who come after us." iTunes and SoundJam users will no doubt be affected to some degree, as both products feature Kerbango support. (Thanks, Michael Robertson)
  2. skiller
    skiller New Member
    what is kerbango?
  3. starwatcher
    kerbango is an internet radio source and division of 3com industries. Due to financial turbulences 3com is forced to close down its internet sector and this might partially affect all iTunes users intensively using kerbangos radio programs . Amazon currently sells a distinct radio tuner which has to be connected to the internet and allows buyers to listen to kerbangos internet program.
    The news has been published on macwelts homepage in the meantime as well.
    So, demnächst reden wir wieder deutsch - gell? (war zu faul, den artikel zu übersetzen)
    :) Klaus
  4. Crustaceae
    Crustaceae New Member
    Die Radiofunktion vom iTunes läuft mit 56k aber ganz und gar ungeschmeidig: Auf 20 Sek. hören folgen 10 Sek. nachladen uswusf.
    Und das, was ich zu hören bekommen habe, klang alles nach Mittelwelle.
  5. thd
    thd New Member
    check mal deine verbindungsgeschwindigkeit. was steht das so? ich vermute mal sowas im bereich von 38 - 44 kbs. und du willst 56 k downloaden? tja, da fehln dann wohl über tausend zeichen pro sekunde...kein wunder das du musik nur aus deinem buffer hörn kannst :) 32k müßten eigentlich imemr laufen. und sind klanglich für nebenbei hörn ok.
    thd
  6. Crustaceae
    Meine Modemleitung steht immer zwischen 44 und 46k. Aber geladen wird fast immer mit etwa 5k, wenn sich mal ne verstopfung gelöst hat kommt mal kurz ein 10k-Klumpen.
  7. Crustaceae
    @ Starwatcher
    Hallo Starwatcher,
    ich habe gesehen, dass Du diplomierter Informierer bist und zusätzlich HobbyAstrologe. Ich würde Dich bitten mir mal meinen Aszendenten auszurechnen. Einschlägige Lit. war bisher unfruchtbar!
    Geb. 01.09.72, 12.10Uhr, Johannesburg
    Danke!!!!!
    Danke!!!!!
  8. thd
    thd New Member
    >>"zusätzlich HobbyAstrologe" auwei . . . verwexle bloß nich astro-nomie und -logie ! :-D
    thd
  9. Crustaceae
    wieso? Mathematik und Sterne "lügen" nie!!!
  10. thd
    thd New Member
    hör bloß uff....starwatcher ist ein excelsior class stern gugger (jawohl. hatta mir selbst gesagt....)
    mit freundlichem gruß
    thd
  11. Crustaceae
    Dann wird doch auch irgendwo meinen Aszendenten sehen können. Ich bleibe bei Versuchen ihn selber zu finden immer am Fenster meiner Nachbarin hängen - vielleicht liegt es aber daran, dass ich nicht so ne gute HighEndMegaGigaEquipmentAusrüstung habe und nur ein Fernglas benutze!
    Ab wann ist man denn "excelsior glass stern gugger? Was bin ICH?
  12. DonRene
    DonRene New Member
  13. thd
    thd New Member
    hallo schalentier.
    ich bin ein mac(trek)ie.
    er ist excelsior class imac wenn ich nich irre :)
    thd
  14. Crustaceae
    Oh Don!
    danke für die Tipps. Ich habs mal ausprobiert: der Kairon errechnet es tatsächlich! Wo hast Du nur solche Sachen her?
    Leider gab es kleine Probleme mit der Uhrzeit.
  15. Crustaceae
    Hä? Hö?
    Er ist doch "excelsior class sterne gugger"? Oder iMac?
  16. thd
    thd New Member
    wadde mal. er sagte folgendes:
    "@thd,
    live long and prosper!
    Klaus - iMac (Excelsior Class):) "
    wie habe ich das zu verstehn :)
    er ist ein imac denk ich.....sterngugger auch
    thd
  17. Crustaceae
    ich deute das so:
    Er ist ein "excelsior class Klaus-iMac!"
    Nach sternegugger sieht das nicht aus!
    Boris
  18. thd
    thd New Member
    nanu. (sach mal du schalentier. sprinsgt du hier auch grad im forum rum und aktualierst alle halbe minute , um zu sehn ob wieder einer was gepostet hat? :-D )
    ja. die excelsior class war doch ne raumschiff klasse. wars nicht die enterprise b? oder c? keeen ahnung jetzt. das bei mir trekkie..arghh
    thd
  19. Crustaceae
    Ja, ich bin gerade online! Und Du?
    Ich kenne mich mit UFOs nicht so aus.
  20. thd
    thd New Member
    ja. habe nix zu tun :)
    thd
