Problem mit ffmpegX
Dieses Thema im Forum "Hardware" wurde erstellt von Balrock, 25. Juli 2003.
  1. Balrock
    Balrock New Member
    Guten Morgen,
    ich habe schon mehrmals versucht unterschiedliche DVD´s mit ffmpegX in SVCD´s zu rippen. Naturlich nach macmercy´s tutorial!
    Leider erzeugt mein ffmpegX immer nur eine .m2v-Datei.
    Das Terminal spuckt folgendes aus:
    Last login: Thu Jul 24 09:24:40 on ttyp1
    pbpaste | sh
    Welcome to Darwin!
    [XXXXXX-Computer:~] XXXXXX% pbpaste | sh
    Encoding started on Thu Jul 24 09:24:42 CEST 2003
    mpeg2dec-0.2.1 - by Michel Lespinasse <walken@zoy.org> and Aaron Holtzman
    Using altivec for IDCT transform
    INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
    INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
    INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
    Using altivec for motion compensation
    Frame rate code = 17960
    MPEG in libvo = 63 aspect_code=82160
    ++ WARN: [mpeg2enc] Generating dummy SVCD scan-data offsets to be filled in by "vcdimager"
    ++ WARN: [mpeg2enc] If you're not using vcdimager you may wish to turn this off using -d
    182546 frames in 19609.28 sec (9.30 fps), 3 last 0.56 sec (5.35 fps)
    182556 frames decoded in 19609.65 seconds (9.30 fps)
    a52dec-0.7.4 - by Michel Lespinasse <walken@zoy.org> and Aaron Holtzman
    No accelerated IMDCT transform found
    0 frames decoded in 0.00 seconds (0.00 fps)
    **ERROR: EOF in WAV header
    **ERROR: failure reading WAV file
    INFO: [mplex] mplex version 2.2.1 ($Date: 2002/04/20 19:08:30 $)
    INFO: [mplex] File /Volumes/Daten/LETHALWEAPON4_PAL2_SIDEA/lethal4.m2v looks like an MPEG Video stream.
    **ERROR: [mplex] Unable to open file /Volumes/Daten/LETHALWEAPON4_PAL2_SIDEA/lethal4.mp2 for reading.
    -2 is not a valid mpeg file
    (Super) VideoCD xml description created successfully as `/Volumes/Daten/LETHALWEAPON4_PAL2_SIDEA/lethal4.1.xml'
    ++ WARN: initializing libvcd 0.7.12 [darwin5.2/powerpc]
    ++ WARN:
    ++ WARN: this is the UNSTABLE development branch!
    ++ WARN: use only if you know what you are doing
    ++ WARN: see http://www.hvrlab.org/~hvr/vcdimager/ for more information
    ++ WARN:
    **ERROR: could not stat() file `/Volumes/Daten/LETHALWEAPON4_PAL2_SIDEA/lethal4-1.mpg': No such file or directory
    rm: /Volumes/Daten/LETHALWEAPON4_PAL2_SIDEA/lethal4-1_02_pregap.img: No such file or directory
    (Super) VideoCD xml description created successfully as `/Volumes/Daten/LETHALWEAPON4_PAL2_SIDEA/lethal4.2.xml'
    ++ WARN:
    ++ WARN:
    **ERROR: could not stat() file `/Volumes/Daten/LETHALWEAPON4_PAL2_SIDEA/lethal4-2.mpg': No such file or directory
    rm: /Volumes/Daten/LETHALWEAPON4_PAL2_SIDEA/lethal4-2_02_pregap.img: No such file or directory
    Encoding completed on Thu Jul 24 14:53:29 CEST 2003
    Was mache ich falsch?
    B.
  2. artvandeley
    artvandeley New Member
    tschä, hm...Dein Compi hat Probleme die Tonspur zu encoden ( **ERROR: EOF in WAV header **ERROR: failure reading WAV file), alle anderen Meldungen hängen damit zusammen. EOF ist End of File, bei 0 Frames...
    Sorry, aber Du bist wirklichwirklich sicher unter Audio die richtige Tonspur gewählt zu haben?Welche ffmpegx-Version benutzt Du? Bei den neueren kann man unter Audio sogar Spur 0 wählen...sehr komfortabel....
    Ansonsten gibts natürlich workarounds um die Tonspur zu demuxen......is allerdings schon zu lange her, kann ich Dir nich mehr beschreiben..
    Andreas G, übernehmen Sie!
    Viel Erfolg
    art
  3. PeterG
    PeterG New Member
    Versuche mit bbdemux oder mpgtxwrap deine Audiospur zu extrahieren. Falls das gelingt, kannst Du sie als MP2 kodieren, z.B. mit MediaPipe oder MissingMPEGTools. Dann mußr Du die M2V- und die MP2-Datei mischen, z.B. mit ffmpeg oder MissingMPEGTools.
  4. naklar
    naklar Active Member
    hi
    ich hatte ziemlich das gleiche problem und ich habe es mit einer älteren ffmpegx version gelöst...
    ich weiss nur noch es hatte die endung g oder h...ev. 0.0.5 g oder so ähnlich!
    falls du es micht mehr hast melde dich wieder...
    gruss naklar
  5. artvandeley
    stimmt, jetzt wo du´s sagst,.....
    bei mir gabs nach 0.0.6g immer nur Probleme mit dem Ton (asyncron, Aussetzer....)
    und bin dann reumütig winselnd zurückgekehrt....
    art
  6. naklar
    hi art!
    stimmt, weil du es mir damals auch gesagt hast! wissens-sharing oder wie sagt man dem? :D
    http://forum.macwelt.de/forum/showthread.php?s=&threadid=69122
    übrigens, bis version 0.0.6h funktioniert es bei mir einwandfrei!
    gruss naklar
  7. artvandeley
    ach du sch$&%§....
    ich werd alt.......:)
    grüße
    art
  8. Balrock
    Balrock New Member
    danke ersteinmal für Eure Tipps!
    Ich habe alles nochmal mit der Version 0.0.4 gerippt
    und folgende Terminal Meldung erhalten:
    Last login: Sat Jul 26 09:39:50 on ttyp1
    pbpaste | sh
    Welcome to Darwin!
    [XXXXXs-Computer:~] XXXXX% pbpaste | sh
    182546 frames in 20658.96 sec (8.83 fps), 3 last 0.57 sec (5.26 fps)
    182556 frames decoded in 20659.32 seconds (8.83 fps)
    INFO: Opened WAV file, freq = 48000 Hz, channels = 2, bits = 16
    INFO: format = 0x1, audio length = 4294967256 bytes
    INFO: slots/frame = 731
    INFO: frac SpF=0.429, tot bitrate=224 kbps, s freq=44.1 kHz
    INFO: Fractional number of slots, padding required
    INFO: System is big endian
    228191 frames in 3499.16 sec (65.21 fps), 63 last 0.94 sec (67.02 fps)
    228196 frames decoded in 3499.17 seconds (65.21 fps)
    INFO: Avg slots/frame = Inf; b/smp = Inf; br = Inf kbps
    INFO: Encoding with psychoacoustic model 2 is finished
    INFO: The MPEG encoded output file name is "/Volumes/Daten/LETHALWEAPON4_PAL2_SIDEA/LETHAL4.mp2"
    INFO: [mplex] File /Volumes/Daten/LETHALWEAPON4_PAL2_SIDEA/LETHAL4.m2v looks like an MPEG Video stream.
    INFO: [mplex] File /Volumes/Daten/LETHALWEAPON4_PAL2_SIDEA/LETHAL4.mp2 looks like an MPEG Audio stream.
    INFO: [mplex] Found 1 video streams 1 MPEG audio streams and 0 AC3 streams
    INFO: [mplex] Selecting SVCD output profile
    INFO: [mplex] Scanning for header info: Video stream e0 (/Volumes/Daten/LETHALWEAPON4_PAL2_SIDEA/LETHAL4.m2v)
    INFO: [mplex] VIDEO STREAM: e0
    INFO: [mplex] Frame width : 480
    INFO: [mplex] Frame height : 576
    INFO: [mplex] Aspect ratio : 4:3 display
    INFO: [mplex] Picture rate : 25.000 frames/sec
    INFO: [mplex] Bit rate : 2500000 bits/sec
    INFO: [mplex] Vbv buffer size : 229376 bytes
    INFO: [mplex] CSPF : 0
    INFO: [mplex] Scanning for header info: Audio stream c0 (/Volumes/Daten/LETHALWEAPON4_PAL2_SIDEA/LETHAL4.mp2)
    INFO: [mplex] AUDIO STREAM:
    INFO: [mplex] Audio version : 1.0
    INFO: [mplex] Layer : 2
    INFO: [mplex] CRC checksums : no
    INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
    INFO: [mplex] Frequency : 44100 Hz
    INFO: [mplex] Mode : 0 stereo
    INFO: [mplex] Mode extension : 0
    INFO: [mplex] Copyright bit : 0 no copyright
    INFO: [mplex] Original/Copy : 0 copy
    INFO: [mplex] Emphasis : 0 none
    INFO: [mplex] SYSTEMS/PROGRAM stream:
    INFO: [mplex] rough-guess multiplexed stream data rate : 2780000
    INFO: [mplex] target data-rate specified : 2788800
    INFO: [mplex] Setting specified specified data rate: 2788800
    INFO: [mplex] Sectors = 78 Video delay = 46800 Audio delay = 46800
    INFO: [mplex] New sequence commences...
    INFO: [mplex] Video e0: buf= 235520 frame=000000 sector=00000000
    INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
    INFO: [mplex] Scanned to end AU 182555
    INFO: [mplex] STREAM e0 completed @ 182555.
    INFO: [mplex] STREAM c0 completed @ 279539.
    INFO: [mplex] Multiplex completion at SCR=657245400.
    INFO: [mplex] Video e0: buf= 234968 frame=182555 sector=00955859
    INFO: [mplex] Audio c0: buf= 2633 frame=279539 sector=00089053
    INFO: [mplex] VIDEO_STATISTICS: e0
    INFO: [mplex] Video Stream length: 272974254 bytes
    INFO: [mplex] Sequence headers: 12481
    INFO: [mplex] Sequence ends : 1
    INFO: [mplex] No. Pictures : 182556
    INFO: [mplex] No. Groups : 12481
    INFO: [mplex] No. I Frames : 12481 avg. size 22727 bytes
    INFO: [mplex] No. P Frames : 48737 avg. size 14089 bytes
    INFO: [mplex] No. B Frames : 121338 avg. size 10000 bytes
    INFO: [mplex] No. D Frames : 0 avg. size 0 bytes
    INFO: [mplex] Average bit-rate : 2392400 bits/sec
    INFO: [mplex] Peak bit-rate : 2720400 bits/sec
    INFO: [mplex] BUFFERING min 15 Buf max 217061
    INFO: [mplex] AUDIO_STATISTICS: c0
    INFO: [mplex] Audio stream length 204463543 bytes.
    INFO: [mplex] Syncwords : 279540
    INFO: [mplex] Frames : 159737 padded
    INFO: [mplex] Frames : 119803 unpadded
    INFO: [mplex] BUFFERING min 16 Buf max 746
    INFO: [mplex]
    INFO: [mplex] MUX STATUS: no under-runs detected.
    Size of Fix: 0x914
    now reapplying junk-header ....
    Now processing /Volumes/Daten/LETHALWEAPON4_PAL2_SIDEA/LETHAL4.mpg [1/2] ...
    Now processing /Volumes/Daten/LETHALWEAPON4_PAL2_SIDEA/LETHAL4.mpg [2/2] ...
    -------Done--------
    (Super) VideoCD xml description created successfully as `/Volumes/Daten/LETHALWEAPON4_PAL2_SIDEA/LETHAL4.1.xml'
    ++ WARN:
    ++ WARN:
    **ERROR: image too big (523119 sectors > 449850 sectors)
    rm: /Volumes/Daten/LETHALWEAPON4_PAL2_SIDEA/LETHAL4-1_02_pregap.img: No such file or directory
    rm: /Volumes/Daten/LETHALWEAPON4_PAL2_SIDEA/LETHAL4-1.toc: No such file or directory
    (Super) VideoCD xml description created successfully as `/Volumes/Daten/LETHALWEAPON4_PAL2_SIDEA/LETHAL4.2.xml'
    ++ WARN:
    ++ WARN:
    **ERROR: image too big (522997 sectors > 449850 sectors)
    rm: /Volumes/Daten/LETHALWEAPON4_PAL2_SIDEA/LETHAL4-2_02_pregap.img: No such file or directory
    rm: /Volumes/Daten/LETHALWEAPON4_PAL2_SIDEA/LETHAL4-2.toc: No such file or directory
    Encoding complete!
    Wat nu?
  9. naklar
    hi
    verstehe ehrlich gesagt nur bahnhof ausser:
    hast du genug platz auf der pladde?
    wenn du "keep elementary streams" unter tools aktiviert hast dann werden alle zwischenschritte auf der platte gespeichert und das sind mit dem .vob-file mehrere gb!
    gruss naklar
  10. Balrock
    Balrock New Member
    ich habe noch genug Platz auf der Pladde!
    ffmpeg erzeugt unter anderem zwei .mpeg-Dateinen die etwas über 1GB groß sind.
    Auch nach dem 2. Versuch bekam ich die Meldung das die Files zu groß sind!
    Kann mir vielleicht einer die 0.0.5er Version mailen?
    Kann man die Binary´s neu installieren?
    B.
  11. naklar
    und auf welche adresse?
  12. Balrock
    Balrock New Member
    bitte hier hin: fergberg@gmx.de
    1000 Dank!
    Ich hoffe damit klappts!
    B.
  13. naklar
    sie haben post...;)
