QS 733Mhz auf OWC G4 1.47Ghz Upgrade
Dieses Thema im Forum "Hardware" wurde erstellt von macster24, 8. September 2003.
  1. macster24
    macster24 Ort: Amsterdam
    Ich hab heute mein neues G4 1.47 Ghz CPU Board bekommen. Deshalb für alle Interessierten hier die XBench Ergebnisse.
    Meine „alte” Hardware:
    QS 733 Mhz, GeForce 4 Ti/128Mb, 733MB RAM :angry:
    Meine „neue” Hardware:
    QS 1.47 Ghz, GeForce 4 Ti/128Mb, 1,5 GB RAM :D
    (RAM war wärend des XBench Test noch nicht installiert)
    QS 733 MHz:
    Results 67.06
    System Info
    Xbench Version 1.0
    System Version 10.2.6
    Physical RAM 768 MB
    Model PowerMac3,5
    Processor PowerPC G4 @ 734 MHz
    Version 7450 (V'ger) v2.0
    L1 Cache 32K (instruction), 32K (data)
    L2 Cache 256K @ 734 MHz
    Bus Frequency 134 MHz
    Video Card GeForce4 Ti 4600
    Drive Type IBM-DTLA-305040
    CPU Test 79.55
    GCD Recursion 83.43 3.26 Mops/sec
    Floating Point Basic 80.59 271.65 Mflop/sec
    AltiVec Basic 70.69 3.84 Gflop/sec
    Floating Point Library 85.17 3.83 Mops/sec
    Thread Test 47.42
    Computation 45.90 369.82 Kops/sec, 4 threads
    Lock Contention 49.04 615.59 Klocks/sec, 4 threads
    Memory Test 72.20
    System 65.86
    Allocate 87.43 29.48 Kalloc/sec
    Fill 68.26 391.43 MB/sec
    Copy 51.38 256.88 MB/sec
    Stream 79.89
    Copy 79.72 348.60 MB/sec [altivec]
    Scale 81.05 353.63 MB/sec [altivec]
    Add 79.38 361.17 MB/sec [altivec]
    Triad 79.42 348.97 MB/sec [altivec]
    Quartz Graphics Test 81.39
    Line 81.34 2.07 Klines/sec [50% alpha]
    Rectangle 94.20 6.63 Krects/sec [50% alpha]
    Circle 93.68 2.16 Kcircles/sec [50% alpha]
    Bezier 75.49 820.24 beziers/sec [50% alpha]
    Text 68.51 1.12 Kchars/sec
    OpenGL Graphics Test 83.27
    Spinning Squares 83.27 58.27 frames/sec
    User Interface Test 59.97
    Elements 59.97 20.41 refresh/sec
    Disk Test 62.89
    Sequential 66.15
    Uncached Write 58.43 25.49 MB/sec [4K blocks]
    Uncached Write 60.40 24.57 MB/sec [256K blocks]
    Uncached Read 97.67 15.38 MB/sec [4K blocks]
    Uncached Read 60.38 26.05 MB/sec [256K blocks]
    Random 59.93
    Uncached Write 51.36 0.78 MB/sec [4K blocks]
    Uncached Write 49.37 11.33 MB/sec [256K blocks]
    Uncached Read 75.24 0.49 MB/sec [4K blocks]
    Uncached Read 72.84 14.28 MB/sec [256K blocks]
    QS 1.47 GHz:
    Results 134.82
    System Info
    Xbench Version 1.0
    Physical RAM 768 MB
    Model PowerMac3,5
    Processor PowerPC G4 @ 1.47 GHz
    Version 7455 (Apollo) v3.3
    L2 Cache 256K @ 1467 MHz
    L3 Cache 2048K @ 4.18 GHz
    Drive Type Maxtor 6Y120L0
    CPU Test 172.78
    GCD Recursion 171.73 6.71 Mops/sec
    Floating Point Basic 163.65 551.61 Mflop/sec
    AltiVec Basic 186.14 10.10 Gflop/sec
    Floating Point Library 171.09 7.68 Mops/sec
    Thread Test 91.15
    Computation 91.16 734.43 Kops/sec, 4 threads
    Lock Contention 91.13 1.14 Mlocks/sec, 4 threads
    Memory Test 110.93
    System 156.53
    Allocate 175.78 59.26 Kalloc/sec
    Fill 380.16 2180.01 MB/sec
    Copy 92.19 460.97 MB/sec
    Stream 85.91
    Copy 86.57 378.58 MB/sec [altivec]
    Scale 87.76 382.89 MB/sec [altivec]
    Add 83.84 381.48 MB/sec [altivec]
    Triad 85.56 375.93 MB/sec [altivec]
    Quartz Graphics Test 177.80
    Line 165.62 4.22 Klines/sec [50% alpha]
    Rectangle 189.98 13.37 Krects/sec [50% alpha]
    Circle 196.51 4.53 Kcircles/sec [50% alpha]
    Bezier 167.51 1.82 Kbeziers/sec [50% alpha]
    Text 173.56 2.83 Kchars/sec
    OpenGL Graphics Test 170.54
    Spinning Squares 170.54 119.34 frames/sec
    User Interface Test 154.52
    Elements 154.52 52.58 refresh/sec
    Disk Test 122.13
    Sequential 133.23
    Uncached Write 128.18 55.93 MB/sec [4K blocks]
    Uncached Write 133.26 54.22 MB/sec [256K blocks]
    Uncached Read 148.24 23.35 MB/sec [4K blocks]
    Uncached Read 125.45 54.12 MB/sec [256K blocks]
    Random 112.74
    Uncached Write 124.38 1.88 MB/sec [4K blocks]
    Uncached Write 119.47 27.41 MB/sec [256K blocks]
    Uncached Read 96.62 0.63 MB/sec [4K blocks]
    Uncached Read 114.69 22.48 MB/sec [256K blocks]
  2. mausbiber
    mausbiber New Member
    Hmm....
    Mehr als die Benchmarks würde mich interessieren:
    Ist der Rechner dadurch lauter geworden?
  3. mac_the_mighty
    Wieviel hat der Spass gekostet und wie sind Deine subjektiven Eindrücke?
  4. macster24
    @ mausbiber
    Nein, der Rechner ist nicht lauter geworden.
    @ Mac_the_mighty
    Zum Eindruck: Ich arbeite häufig an einem dual 1.25. Mein Rechner fühlt sich subjektiv betrachtet deutlich fixer an. X zuppt wie in alten 9er Tagen. Ich denke das liegt auch an meiner Grafikkarte. Der 1.25 hat nur die Standard Karte verbaut.
    Die Leistung hat sich mehr als verdoppelt. Inbesondere in Spielen wie UT2003 und americas Army macht sich der Cache und die hohe Taktung bemerkbar. Alle Optionen an, höchste Auflösung und über 50 FPS+.
    Zum Preis: inkl. Versand (direkt US) innerhalb 3 Tagen via FedEx $620.
  5. macster24
    QS 733 MHz:
    Results 67.06
    System Info
    Xbench Version 1.0
    Physical RAM 768 MB
    Model PowerMac3,5
    CPU Test 79.55
    Thread Test 47.42
    Memory Test 72.20
    System 65.86
    Stream 79.89
    Disk Test 62.89
    Sequential 66.15
    Random 59.93
    QS 1.47 GHz:
    Results 134.82
    System Info
    Xbench Version 1.0
    Physical RAM 768 MB
    Model PowerMac3,5
    CPU Test 172.78
    Thread Test 91.15
    Memory Test 110.93
    System 156.53
    Stream 85.91
    Disk Test 122.13
    Sequential 133.23
    Random 112.74
  6. mausbiber
    Hmm....
  7. mac_the_mighty
  8. macster24
    @ mausbiber
    @ Mac_the_mighty
  9. macster24
    QS 733 MHz:
    Results 67.06
    System Info
    Xbench Version 1.0
    Physical RAM 768 MB
    Model PowerMac3,5
    CPU Test 79.55
    Thread Test 47.42
    Memory Test 72.20
    System 65.86
    Stream 79.89
    Disk Test 62.89
    Sequential 66.15
    Random 59.93
    QS 1.47 GHz:
    Results 134.82
    System Info
    Xbench Version 1.0
    Physical RAM 768 MB
    Model PowerMac3,5
    CPU Test 172.78
    Thread Test 91.15
    Memory Test 110.93
    System 156.53
    Stream 85.91
    Disk Test 122.13
    Sequential 133.23
    Random 112.74
  10. mausbiber
    Hmm....
  11. mac_the_mighty
  12. macster24
    @ mausbiber
    @ Mac_the_mighty
  13. mike bols
    mike bols New Member
    hallo,
    wie akkurat sind denn diese xbench daten?
    ein freund von mir hat einen cube/450mhz und kommt auf score 29.
    ich selbst habe einen g4/800 mit 64mb graphik und komme auf ca. 32
    gestern testeten wir eine quicksilver dual 1.7 und kamen auf 56 punkte.
    das ist alles meilenweit von euren ergebnissen entfernt.
    woran kann das liegen?
  14. mike bols
    Results 54.77
    System Info
    Xbench Version 1.2
    System Version 10.4.4 (8G32)
    Physical RAM 512 MB
    Model PowerMac3,5
    Processor PowerPC G4x2 @ 1.60 GHz
    Version 7450 (V'ger) v2.3
    L1 Cache 16K (instruction), 16K (data)
    L2 Cache 512K
    Video Card GeForce4 MX
    Drive Type IBM-IC35L080AVVA07-0
    CPU Test 67.82
    GCD Loop 147.24 7.76 Mops/sec
    Floating Point Basic 44.71 1.06 Gflop/sec
    vecLib FFT 96.17 3.17 Gflop/sec
    Floating Point Library 51.49 8.97 Mops/sec
    Thread Test 116.09
    Computation 135.78 2.75 Mops/sec, 4 threads
    Lock Contention 101.39 4.36 Mlocks/sec, 4 threads
    Memory Test 23.54
    System 28.65
    Allocate 148.29 544.57 Kalloc/sec
    Fill 33.39 1623.72 MB/sec
    Copy 14.70 303.61 MB/sec
    Stream 19.97
    Copy 20.68 427.16 MB/sec [altivec]
    Scale 20.24 418.08 MB/sec [altivec]
    Add 19.30 411.16 MB/sec [altivec]
    Triad 19.73 422.05 MB/sec [altivec]
    Quartz Graphics Test 70.43
    Line 62.07 4.13 Klines/sec [50% alpha]
    Rectangle 65.32 19.50 Krects/sec [50% alpha]
    Circle 66.22 5.40 Kcircles/sec [50% alpha]
    Bezier 76.84 1.94 Kbeziers/sec [50% alpha]
    Text 87.28 5.46 Kchars/sec
    OpenGL Graphics Test 89.04
    Spinning Squares 89.04 112.95 frames/sec
    User Interface Test 57.68
    Elements 57.68 264.71 refresh/sec
    Disk Test 52.13
    Sequential 83.55
    Uncached Write 75.74 46.50 MB/sec [4K blocks]
    Uncached Write 80.01 45.27 MB/sec [256K blocks]
    Uncached Read 90.68 26.54 MB/sec [4K blocks]
    Uncached Read 89.70 45.08 MB/sec [256K blocks]
    Random 37.88
    Uncached Write 13.76 1.46 MB/sec [4K blocks]
    Uncached Write 71.85 23.00 MB/sec [256K blocks]
    Uncached Read 92.72 0.66 MB/sec [4K blocks]
    Uncached Read 121.77 22.60 MB/sec [256K blocks]
  15. stefpappie
    stefpappie New Member
    und hier mein G4 DA mit encore 1ghz und 1500mb ram
    und was sagt mir das jetzt??:confused:
    Results 93.11
    System Info
    Xbench Version 1.1.3
    Physical RAM 1024 MB
    Model PowerMac3,4
    Processor PowerPC G4 @ 1.00 GHz
    Version 7455 (Apollo) v2.1
    L2 Cache 256K @ 500 MHz
    L3 Cache 2048K @ 250 MHz
    Video Card ATY,RV100
    Drive Type SAMSUNG SV1203N
    CPU Test 106.42
    GCD Loop 98.26 3.84 Mops/sec
    Floating Point Basic 106.98 386.87 Mflop/sec
    AltiVec Basic 112.43 3.27 Gflop/sec
    vecLib FFT 122.19 1.90 Gflop/sec
    Floating Point Library 96.33 3.86 Mops/sec
    Thread Test 73.12
    Computation 51.77 698.96 Kops/sec, 4 threads
    Lock Contention 124.42 1.56 Mlocks/sec, 4 threads
    Memory Test 108.75
    System 125.99
    Allocate 431.02 281.16 Kalloc/sec
    Fill 140.54 1118.70 MB/sec
    Copy 69.56 347.80 MB/sec
    Stream 95.67
    Copy 95.61 698.89 MB/sec [altivec]
    Scale 96.11 709.30 MB/sec [altivec]
    Add 97.15 621.75 MB/sec [altivec]
    Triad 93.86 573.50 MB/sec [altivec]
    Quartz Graphics Test 85.94
    Line 68.09 1.73 Klines/sec [50% alpha]
    Rectangle 77.84 5.48 Krects/sec [50% alpha]
    Circle 82.12 1.89 Kcircles/sec [50% alpha]
    Bezier 84.04 913.17 beziers/sec [50% alpha]
    Text 152.14 2.48 Kchars/sec
    OpenGL Graphics Test 72.43
    Spinning Squares 72.43 50.68 frames/sec
    User Interface Test 161.76
    Elements 161.76 52.03 refresh/sec
    Disk Test 88.60
    Sequential 99.25
    Uncached Write 99.10 41.31 MB/sec [4K blocks]
    Uncached Write 96.17 39.38 MB/sec [256K blocks]
    Uncached Read 99.22 15.71 MB/sec [4K blocks]
    Uncached Read 102.75 41.51 MB/sec [256K blocks]
    Random 80.00
    Uncached Write 72.22 1.08 MB/sec [4K blocks]
    Uncached Write 93.31 21.04 MB/sec [256K blocks]
    Uncached Read 72.18 0.48 MB/sec [4K blocks]
    Uncached Read 86.37 17.77 MB/sec [256K blocks]
  16. mike bols
    das dein rechner mit 1ghz prozessor doppelt so schnell ist wie meiner
    mit 2x 1,6ghz ???
  17. Eduard
    Eduard New Member
    @ macaster24:
    Schaffst Du noch mit System 10.2.6?
    Panther läuft deutlich besser und kann auch deutlich mehr. Wo Du schon so viel Geld in das Upgrade steckst... Tiger muß nicht, aber Panther bis 10.3.9 schon :nicken:
  18. stefpappie
    wenn das so wäre, dann :rolleyes::rolleyes::rolleyes:
    aber der kasten lahmt und hängt und ja, der firefox war beim xbenchen auch noch an...
    saudoofe technik...
    der stef
  19. derbaer
    derbaer New Member
    2 verschiedene xBench-Versionen bei den Tests zuvor^^
    Bei Vers. 1.1.3 ist die Referenz (=100%) ein G4 Dual 800 Mhz, ab Vers. 1.2x ein G5 Dual 2,0 Ghz !
    Beide Tests sind also nicht zu vergleichen....
