Treiber für CD/RW/DVD-Laufwerke
Dieses Thema im Forum "Hardware" wurde erstellt von TomPo, 18. Dezember 2002.
  1. TomPo
    TomPo Active Member
    OS X 10.2/iTunes 3 Info:
    http://forums.xlr8yourmac.com/software/LiteOn48125S_JagPlugin.sit
    http://forums.xlr8yourmac.com/software/LiteOn48126S_JAGplugin.sit
    http://forums.xlr8yourmac.com/software/LiteOn52xJAGplugin.sit.hqx
    http://forums.xlr8yourmac.com/software/LG8320B_JAG-plugin.sit
    http://forums.xlr8yourmac.com/software/Philips24x_JaguarPlugin.sit
    OS X 10.2/iTunes3 support file for the Sony CRX210A1 48x12x48x
    http://homepage.mac.com/anhline/files/SonyCDR.device-plugin.sit
    http://forums.xlr8yourmac.com/software/Sony195A1_JAG_plugin.sit
    http://forums.xlr8yourmac.com/software/Sonycrx185E3_JAG-plugin.sit
    OS X 10.2/iTunes support file for the Toshiba SD1202 Combo DVD/CDRW Drive
    http://forums.xlr8yourmac.com/software/ToshibaSD1202_plugin_jag.sit
    Für OS X 10.2.1
    http://forums.xlr8yourmac.com/software/LG_8120B_JAGplugin.sit
    http://forums.xlr8yourmac.com/software/LG8400BCDR.device-plugin.sit
    Für OS X 10.1.x
    http://forums.xlr8yourmac.com/software/LG8120Bdevice-plugin.sit
    OS 9 Support-Files:
    http://forums.xlr8yourmac.com/software/PioneerA05_105_CDR.sit
    OS X 10.2.x/iTunes3/iDVD2 support for a Toshiba SD-R5002 DVD Recorder Drive
    http://forums.xlr8yourmac.com/software/ToshibaSD-R5002_JAGplugin.sit
    http://forums.xlr8yourmac.com/software/RicohMP9120_JAGplugin.zip
    OS X 10.2/iTunes3 support for a Memorex 48MAXX CDRW Drive
    http://forums.xlr8yourmac.com/software/MemorexCDR_JAGplugin.sit
    OS X.2 iTunes 3 support für Yamaha CRW-F1 (44x24x44x)
    http://forums.xlr8yourmac.com/software/YamahaCRW-F1_JAGplugin.sit
    OS X 10.2/iTunes3 support for the Samsung SM-332B Combo DVD+CDRW Drive
    http://forums.xlr8yourmac.com/software/Samsung332B_JAGplugin.sit
    OS 9.x iTunes Support for a Lite-On 48125W 48x CDRW
    http://forums.xlr8yourmac.com/software/Lite48125W_OS9.sit
    iTunes support für das Yamaha CRW-F1 CDRW Drive -> OS 9
    http://forums.xlr8yourmac.com/software/YamahaF1CDR.sit
    TDK
    OS X 10.2.1/iTunes 3 Support file for a TDK 48x CDRW
    http://forums.xlr8yourmac.com/software/TDKCDR4800B_JAG_plugin.sit
    support file for a TDK 40x12x48x CDRW
    http://forums.xlr8yourmac.com/software/TDK_40x_JAG_plugin.sit
    Support file for a TDK 32x10x40x CDRW
    http://forums.xlr8yourmac.com/software/TDK32x_JAGplugin.dmg.gz
    Samsung-Drives
    iTunes OS X support file for the Samsung SW-240 40x12x40x CDRW Drive
    http://forums.xlr8yourmac.com/software/SamsungSW-240_JAGplugin.sit
    Samsung SW-224B 24x10x40x CDRW drive OS X 10.2/iTunes 3 OS 9:
    http://forums.xlr8yourmac.com/software/SamsungCDR-SW224B-MacOS9.2.sit
    OS X: http://forums.xlr8yourmac.com/software/SamsungCDR-SW224B-MacOSX.sit
    OS X 10.1.x und iTunes-Support für Pioneer DVR-105
    http://forums.xlr8yourmac.com/software/PioneerDVR105_10_1plugin.sit
    regionfree firmware (ohne Garantie) für Pioneer DVR-104_A227
    wird nur von iMac 2002 (TFT) und QS G4 (2002) unterstützt
    http://195.134.134.27/downloads/macdvd/Pioneer_DVR-104_A227.bin
    z.Z. konnten keine NECs gefunden werden, sorry
  2. kobayjashi
    kobayjashi New Member
    hi
    habe hier einen kleinen erfahrungsbericht zum thema Combo Laufwerke.
    haben mir vor 2 wochen ein samsung 332 combo für 90¬ bei saturn gekauft und was soll ich sagen es läuft wunderbar mit einem G4/800 mit 10.2. habe mir allerdins auch auf www.xlr8yourmac.com den dazugehörigen patch besorgt.
    gruß
    kobayjashi
  3. TomPo
    TomPo Active Member
    Ja, auch mein LG-Combo wurde auch erst durch eines dieser Patches zum "Vollwertigen".
    Vielleicht sollte man Apple mal ´ne Liste mit allen verfügbaren Laufwerken mailen, damit sie hier für Abhilfe sorgen können. Ist ja eigentlich deren Problem, nicht unseres.
  4. carlo
    carlo New Member
    Hi tompo,
    suche noch einen patch oder zumindest ein herstellerspezifisches device-plugin für NEC-brenner. Ich hab bislang nichts gefunden. Gibts da deines wissens was?
    Gruß,
    carlo
  5. TomPo
    TomPo Active Member
    Hab´s schon in anderen Foren gelesen, sieht für NECs nicht gut aus. Ich sehe aber noch mal woanders nach.
    cul
  6. faustino18
    faustino18 New Member
    Hallo TomPo,
    hast du zufällig Infos wie's mit den Treibern für Freecom-Brenner (FW, Portable) aussieht? Auf der Seite, von der du die Links gepostet hast, gibts nix für Freecom und beim Support werde ich nicht wahrgenommen. (Verdammter Shiet!!!)
    Bis denne HDT
    Patrick
  7. Macsimpsons
    Macsimpsons New Member
    und wo bleibt der von Freecom (Firewire?)
  8. ratlos
    ratlos www.jvmd.de
    Hallo :)
    Freecom Traveller 1  FireWire...
    ...wo gibts da denn Treiber/Patches?
    Jörg
  9. TomPo
    TomPo Active Member
    Freecom? Funtzen die nicht ohne irgendwelches dazutun?
    Bei Freecom und manchen anderen ist das das Problem, dass die ja keine eigenen Geräte herstellen (Formac), sondern nur Laufwerke verbauen. Somit ist es schwierig, Treiber zu finden. In jedes Drive muss nicht unbedingt das gleiche LW eingebaut worden zu sein (siehe Apple, die verbauen auch was sie gerade billigst abgestaubt haben).
    aber ich werde noch mal die pupille werfen.
  10. Macsimpsons
    Suche noch immer nen iTunes Treiber für den firewire Freecom 40/10/40!
  11. Macsimpsons
    ... bin noch auf der Suche!
  12. TomPo
    TomPo Active Member
    re buying has an open face front bezel to allow the CD drive tray.
    (Some cases are sold for Hard drives only - without a front case opening, and/or are sized too small for a CD size drive.)
    Most of the Firewire case kit bridges now are based on the Oxford 911 bridge which is usually set to "auto" detect the drive type (Hard drive or CD/CDRW, etc. drive). However verify this before buying and again make sure the case will fit a 5.25" (CD size) drive and has an open face/removable plate front bezel if you're planning on using it for a CD/CDRW/DVD, etc. drive instead of a hard drive.
    so sieht es zur Zeit aus.
    prüf mal deine FW-Bridge, sollte den (aktuellen) Oxford911 Chipsatz haben. ist´s nicht, sieht´s nicht gut aus.
