vega strike und nix geht!
Dieses Thema im Forum "Hardware" wurde erstellt von neumi, 6. Januar 2003.
  1. neumi
    neumi New Member
    habe vega strike 0.3.0 gezogen und wollte es antesten, es crashed aber gleich nach doppelclick.
    die console meldet:
    Vega Strike
    See http://www.gnu.org/copyleft/gpl.html for license details.
    Data directory is /Applications/Vega Strike 0.3.0.app/Contents/Resources/data/.
    no name or value given for variable
    using config file in data dir /Applications/Vega Strike 0.3.0.app/Contents/Resources/data/.
    SIMULATION_ATOM: 0.06
    WARNING: no var named directory in section data using default: /Applications/Vega Strike 0.3.0.app/Contents/Resources/data/.
    WARNING: no var named sharedmeshes in section data using default: meshes
    WARNING: no var named sharedunits in section data using default: units
    Could not find platform independent libraries
    Could not find platform dependent libraries <exec_prefix>
    Consider setting $PYTHONHOME to [:<exec_prefix>]
    dyld: /Applications/Vega Strike 0.3.0.app/Contents/MacOS/vegastrike Undefined symbols:
    /Applications/Vega Strike 0.3.0.app/Contents/MacOS/vegastrike undefined reference to _ceilf expected to be defined in /usr/lib/libSystem.B.dylib
    /Applications/Vega Strike 0.3.0.app/Contents/MacOS/vegastrike undefined reference to _floorf expected to be defined in /usr/lib/libSystem.B.dylib
    /Applications/Vega Strike 0.3.0.app/Contents/MacOS/vegastrike undefined reference to _fmodf expected to be defined in /usr/lib/libSystem.B.dylib
    Could not connect to host
    48 Error
    hat jemand eine idee, was mir die console damit sagen will??
    danke
  2. neumi
    neumi New Member
    ich heb mir noch 'nen bruch:
    und hoch damit!
